Question Keystone wallplates with 8 or 9 ports - does such a product exist? Where?
Tepid Mess
35
Hi! I'm not sure if I've located the best place to post this question, but it's an easy question. At least it's easy to understand the question. :)
I want to buy a SINGLE GANG wall plate, that has either 8 or 9 keystone ports.
I can easily find up to six, and I can find as many as 12 in a double-gang without searching too hard, but I want one gang with 8 or 9 ports. Either 8 or 9 will work for me.
I would have thought this would be a no-brainer, but so far I cannot find any such thing. Does such a product exist? If so, can someone point me to an online retailer or store where I can find such a thing?
Thanks You!
And I will add the thought that if you only need 8 or 9 keystone ports and find such a product then Murphy's Law will kick in and you will need 10, 11, or 12 ports. :)
Plan for growth and install two 6 gang wall plates.
Be sure to diagram or otherwise document the connections being used.
Just my thoughts on the matter.
