Hello I've used my custom built computer for about a year now without any real issues whatsoever. I recently fresh installed windows to clean up some virus crap. Everything was great and the computer is operating at full performance after the re installation, however ive realized that my Ethernet connection periodically drops when under stress on online video games/watching streams. I understand that issues like this can be sort of hard to fix but any help would be great.
Things I have done to try to remedy situation:
-Update Killer network drivers
-Secured physical connection to modem
-Removed old windows files using disk clean up
-made sure that the pc cannot turnoff killer adapter for power
-tried using an older version of killer network
On the original ssd the issue did not exist
Specs:
-i5660k stable oc@ 4.4ghz
-1070 turboed to 2000ghz
-16gb ddr4 ram
-plenty of ventilation and cooling
-additional 1tb hard drive
Any additional questions will gladly be answered ive had this issue in the past when i had to make a new boot drive. to fix it back then someone had sent me a killer network version?
if you think it would help a quick tutorial on how to use default windows drivers would be helpful
Specs:
-16gb ddr4 ram
