Kind of consued how to set my fans up as my rear fans are intake
Esaelias187
338
i havew a corsair h50 push and pull intake:
case rear>>>fan1 >>>>> fan 2>>> air comes in
now i know rear fans usually exhaust but in this case it is intake
so shall i turn my front two fronts blowing air out to the front (usually blowing back)
and the two fans on top of case blow air out?
i have a corsiar spec 01
i also have the spec 01. It depends what gets hottest. I have my sedion 120v exhausting the hot air out the back, 2 top exhaust, and 2 front intake. For me its more important to the stability of my 7970 OC to keep hot air away from it, i don't have much of an oc on my cpu only 4ghz. I have considered changing the 120v to intake, but i'm lazy and everything is working fine currently. I don't think it would be an issue to change it to intake if the 2 top fans are exhausting that warmer air straight out?
ok i will change this to <<<<< case <<<<<< fan 1 <<<<<<fan 2
what are your temps
yh i am going to get two coolermaster sickle pro with 2000 rpm and exhaust these from top
i ahve two fans inf ront blowing air in
i am going to change my corsaihr h50 to exhaust, even tho it is good intake i ll try the other way
