B bkoop Honorable Apr 1, 2012 612 0 11,160 Jun 20, 2015 #1 What should I use to test the Kindle wifi speed? I tried cNet and the test part of the page just does not load and I tried speedtest.net by Ookla and it says requires flash.
Solution delaro Jun 22, 2015 Speedtest.net Mobile Speed Test http://www.amazon.com/Ookla-Speedtest-net-Mobile-Speed-Test/dp/B00F9F1G4U or Wi-Fi Analyzer http://www.amazon.com/x8881-x6653-x8F89-Wi-Fi-Analyzer/dp/B004EBZX6W/ref=sr_1_6?s=mobile-apps&ie=UTF8&qid=1435027925&sr=1-6&keywords=wifi+speed+test Both seem to work fine on my Kindle Fire and Kindle Fire HD.
USAFRet Titan Moderator Mar 16, 2013 179,713 22,062 184,590 Jun 20, 2015 #2 Why are you trying to test your WiFi performance with a Kindle? Upvote 0 Downvote
B bkoop Honorable Apr 1, 2012 612 0 11,160 Jun 20, 2015 #3 USAFRet : Why are you trying to test your WiFi performance with a Kindle? Because sometimes the smartTV freezes while playing Netflix movies, so I wanted to check the wifi speed. Upvote 0 Downvote
delaro Judicious Ambassador Aug 23, 2011 4,427 248 33,740 Jun 20, 2015 #4 What Modem/Router are you using and what service are you paying for? Upvote 0 Downvote
B bkoop Honorable Apr 1, 2012 612 0 11,160 Jun 21, 2015 #5 delaro : What Modem/Router are you using and what service are you paying for? Brighthouse cable modem and 35 Mbps Upvote 0 Downvote
delaro Judicious Ambassador Aug 23, 2011 4,427 248 33,740 Jun 22, 2015 Solution #6 Speedtest.net Mobile Speed Test http://www.amazon.com/Ookla-Speedtest-net-Mobile-Speed-Test/dp/B00F9F1G4U or Wi-Fi Analyzer http://www.amazon.com/x8881-x6653-x8F89-Wi-Fi-Analyzer/dp/B004EBZX6W/ref=sr_1_6?s=mobile-apps&ie=UTF8&qid=1435027925&sr=1-6&keywords=wifi+speed+test Both seem to work fine on my Kindle Fire and Kindle Fire HD. Upvote 0 Downvote Solution
B bkoop Honorable Apr 1, 2012 612 0 11,160 Jun 23, 2015 #7 Thanks to all that replied. Upvote 0 Downvote
