Kingston DT Micro Duo MicroUSB/USB Drive is Tiny Awesome
Thats pretty slick and might be a way to expand storage on cellphones and tablets. I am curious to see what kinda pricing where looking at, if its reasonable I might have to pick one up.
Love the nails! Made me smile. Wonder someday if you could put ads on them (Intel Inside, AMD....) and make some cash on the side!As for the drive, I like seeing these concepts with two ends. Although I find it generally cheaper just to get a $2 adapter from China and plug in any cheap USB drive (not to mention a keyboard, mouse, controller...). But this is for the more non-techy crowd, although i love the size, something you could easily attach to a phonestrap.
Like shadow said, there are OTG cables. Exact same thing as this except they are in more of a cable form.
Great, now finally make something similar with SD and microSD connectors, so that I am not limited to the 64GB microSD size limitation on my Android tablet and can use my 128GB/256GB SD cards. Without having to use some wonky glued-together adapter from China. I never understood anyway why tablets do not have full-sized SD card slots.
