J Jujan Reputable Aug 14, 2014 1 0 4,510 Aug 14, 2014 #1 Okay, i bought a 2x4GB RAM Kit, In BIOS I set fixed speed 1600Mhz (which was made on) but CPU-Z shows only 800Mhz (see picture). How is this possible?
J junkeymonkey Polypheme BANNED Nov 11, 2013 17,389 4 66,960 Aug 14, 2014 #2 that's correct duel sided/channel memory 800 +800 = 1600 DDR (Double Data Rate) RAM is designed to transfer data twice per clock cycle. 800Mhz x 2 transfers per clock = 1600Mhz effective.
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Aug 14, 2014 #3 Yes DDR = DOUBLE Data rate so true freq (800) times 2 = effective rate (1600) (though the Double sided has nothing to do with it, there's also single sided DDR which is still Double data rate
