I searched a bit on google about safe DDR3 voltage values and got a bit scared because some ppl sad that you can damage your CPUs memory controller if u run a memory with 1.65v.
So as i have KHX1600C9D3/4GX witch runs on 1600mhz and 1.65 i thought it would be safer to downclock it to 1333 and 1.5v so i first used aida64 to check the voltage and to my surprise it was 1.5v but i thought it was an error and booted into bios to adjust it and even the bios showed something 1.485 don't remember the exact value but it was below 1.5 a bit , there was a option besides auto and it was extreme memory profile when that was checked my ram voltage went up to 1.65 but i changed it back to auto , so am i safe running 1600mhz with 1.5v is there and degrade in performance ? I dont care much if my ram dies its not really expensive but i don't want to buy another CPU because it wasn't cheap at least for my budget.
Here is a SS of aida and cpu-z
EDIT:
My system
CPU : AMD FX 6300
Motherboard: Gigabyte GA-970A-DS3P
GPU Nvidia 450gts
DDR3 ram : 1 stick 4gb Kingston HyperX KHX1600C9D3/4GX
PSU Chiftec 750w
EDIT:
My system
CPU : AMD FX 6300
GPU Nvidia 450gts
PSU Chiftec 750w
