Hello,
Here is my issue: I have a pc with a 3570K cpu and an Gigabyte Z77X-UD3H motherboard. On SATA0 I have a 120GB Kingston SSD V300, that hosts my OS(Windows 8.1) and on SATA1 I have a newly purchased 240GB Kingston SSD V300 that I want to use for some virtual machines. Both SATA0 and SATA1 are SATA3 ports on this mobo. I have the AHCI option selected in BIOS(I guess this applies to all the drives since there is no option to turn it on/off per drive). Both disks are formated with a 4096 bytes allocation unit size, and the device manager says the drivers are up to date for both.
Exact model of the drives:
120 GB drive: SV300S37A120G
240 GB drive: SV300S37A240G
So I guess they are the same apart from the size.
The 120GB drive that hosts my OS works fine, I get pretty close to the manufacturer advertised performance on it, but the 240GB SSD is slow, Add to that that the 120 GB is almost a year old, and the 240 disk is brand new.
120 GB disk performance as tested with Crystal disk mark:
R=Read, W=Write
Sequential: R: 433, W:142
512K: R: 394, W: 132
4k: R: 18, W: 65
4k qd32: R:105; W:140
240 GB disk performance as tested with Cristal disk mark:
Sequential R: 188, W:231
512K : R:179, W 229
4k: R:22, W: 67
4k qd32: R:123, W:219.2
The 240 GB drive is slightly better than a good mechanical disk(some 20% better than my Caviar Black disk) but it should be much faster, at least as fast as the 120 GB drive.
Any idea what might be causing this? If I have a shitty drive, I should be able to get a replacement or refund but I am not sure if I missed something.
Hope I didn't leave any relevenat information out and thanks in advance for your insight,
Paul
R=Read, W=Write
4k: R: 18, W: 65
512K : R:179, W 229
4k: R:22, W: 67
Paul
