G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
My system's power supply (Antec 300 Watt)failed. I replaced the
defective power supply with a good supply, the machine turns on only
long enough for the CPU fan and case fan to begin to spin. Then power
goes away. The system is a MSI KM4M motherboard, AMD Athlon 1800 cpu and
Micron memory. Case is an Antec SLK2600AMB.
What would cause the above symptoms?
Thanks,
Lloyd
Thanks,
Lloyd
