KnuEdge Announces 'KnuVerse' Voice Authentication Technology And 'KnuPath' Neural Chip
bit_user
Ambassador
KnuPath is an ASIC-like chip architecture
What's an "ASIC-like chip architecture"?
ASIC is an implementation method - not an architecture. The same design could be implemented on a FPGA, if it will fit.
256 GFLOPS in 34 W doesn't sound particularly impressive. Maybe they had trouble finding mil-spec parts that were fast & efficient enough, but it seems like both Movidius and Tegra TX-1 are more efficient.
Neither has 40 GB/sec of PCIe, though. It's kinda hard to see why they'd need so much I/O bandwidth, unless you need to interconnect a bunch of these to do anything useful. In that case, I'd have to ask: why not just use a bigger GPU?
SillieAbbe
Commendable
Mar 31, 2016
8
They seem to be misinformed. Whether voice or fingerprints, biometrics should not be activated if you are security-conscious.
It is now getting known that the authentication by biometrics usually comes with poorer security than PIN/password-only authentication. The following video explains how biomerics makes a backdoor to password-protected information.
https://youtu.be/5e2oHZccMe4
