Kolink observatory rgb fan control via rgb fusion
stuartharrison58
Commendable
Jul 10, 2018
20
Is there anyway i can use my fans from my kolink observatory and use them/pair them with rgb fusion or are they the type of fans that are only controlled via the hub and controller provided?
On the case or in case manual, is there any hint that the RGB fans support Gigabyte RGB Fusion? If it is, then they should work with RGB Fusion. But if there's not (which i think is the case) then only included controller works for the fans.
