Hello
I need help connecting the NZXT connector as it is currently unplugged, the cooler has no RGB working so I know its the RGB connections I just have no idea how to connect it to my system.
CPU Cooler - Kraken 120 (not the M22 this seems to be a older model)
Mobo - B450-A PRO MAX
I am unsure on how to correctly plug the four connections from my new cooler into my PC.
There are 4 wires that need to be connected:
2 from Pump - 1 x 4 pin and one NZXT connector (the 4 pin I think is correct in the CPU-fan on the mobo but the NZXT connector I have no idea)
2 from Rad/Fan - 1 x 3 pin and 1 x 4 pin (these I believe I have correctly installed to a sys-fan and pump-fan on mobo
Any advise would be amazing.
Thanks
Here is the Kraken 120 Manual (if its any use)
Thanks
