Good day dear people,
Specs:
Mobo: MSI Z170a Sli Plus
Cpu: i7 6700k
Gpu: 5700xt red devil
Ram: 4x4 Hyper X 2600 16 GB
Cooler: NZXT Kraken X62
Case: Lian Li PC 0 Dynamik
Fans: 6x Coolermaster Halo argb 120 mm
Storage: Samsung 970 Evo 1tb M.2. SSD
I have a question you can maybe help me answer. I didn't find the solution in the search options...
I have a Kraken X62 and now have 6 new Coolermaster Halo fans for the case. My pretty old MSI Z170a Sli Plus is pretty limited in terms of pwm control, so that I basically have to use a fan hub (in my case arctic 10 fan hub) to power and especially control all those fans. The problem is, that the AIO uses both remaining CPU Fan headers. The sys fan headers on this board won't allow me to regulate the speed of the case fans. Whatever I do, bios, speed fan etc. they are on 100 percent and frankly unbearable loud for non headphone use. That issue would only be solved by connecting the hub to one of the two cpu header. Now the price question... Can I put the pump fans on the hub (first slot to read out speed) and use the cpu header for the hub? Or put the hub in one of the x62 fan cable splitter? Don't eat me alive if this question sounds stupid to you. I'm just not sure at all and if there is no solution, well, that would be kinda bad I'm happy for any hint or tipp! Because the volume drives me insane...
Best regards
Specs:
Cpu: i7 6700k
Best regards
