So I just recently built my first PC, and i was having some issues with size constraints within my build. Supposedly if you use a Kracken X62 aio with a Corsair 570x, and a Gigabyte Aorus Ultra (or similar Aorus), the X62 won't fit top mounted in the case due to a heat sink at the top of the motherboard preventing the Radiator/Fan combo from fitting.
I was able to make this it end up fitting by removing one of the Fans from the radiator, so now I have it mounted to the top of the case with a single 140mm fan attached. I thought I should probably counteract this loss and buy another fan, so I bought a Corsair Pro Magnetic Levitation fan (120mm) and was planning to attach it to the back as a rear outtake.
I should also mention the Corsair 570x case comes with a 3x120mm fan intake at the front of the case.
My questions relating to this are:
- What individual effect does removing the fan from the radiator cause in terms of performance?
- Does the addition of a rear outtake fan like I mentioned adequately compensate for any cooling lost with the removal of the radiator fan?
- Would stress testing without that additional fan be fine?
- CPU: Intel i7 9700k
- GPU: EVGA GeForce RTX 2080 XC gaming
- RAM: 2x16 G-skill Trident z
- PSU: Corsair 1000Hx 80+ platinum
- SSD(M2): Samsung 970 Evo Plus
- AIO: NZXT kraken X62
