Kyocera FS680 will not print postcards
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Using MS Word, I am trying to make the Kyocera printer FS 690 print
the back of a postcard.
I does not matter how I handle Word and Kyocera settings of paper
size. I put an A4 in just to see what happens and the A4 is printed in
the top left corner in landscape mode as required, just about the
correct size, but when you place a card in the printer, the left side
of the card comes out with a miserable 2 to 3 last characters of the
last 12-14 lines, in the extreme left of the card, leaving the card
nearly blank.
If I increase the margins top and left to bring the printing to the
card, the print get chewed up and only half of each line is printed
and the rest of the line is on the second line and so on.
I get to think that Kyocera is the most useless printer you can
possibly get - unless I am extremely stupid
B.Pedersen Latitude -31,48.21 Longitude115,47.40 Time=GMT+8.00
If you are curious look here http://www.mapquest.com/maps/latlong.adp
Hi
With this type of printer it isnt really possible to handle postcards: what you
really need is a printer with a straight paper path. Such a printer as eg the
brother 660 hl which you feed the printer in at the back top and it comes out
at the bottom front might do it.
kasfig@aol.com
