Archived from groups: alt.comp.periphs.mainboard.elitegroup (
More info?)
"tomW" <tom24_ca@yahoo.com> wrote in message
news:Irr1d.7174$0h7.586378@news20.bellglobal.com...
> Actually I bought it as part of a kit from a store. I had someone
else put
> it together, but assumed the fan came with the motherboard. I had
a look
> at the fan and it has pro 3200 written on it. The motherboard can
be seen
> on the taiwanese site.
Don't know where you can find the exact replacement fan, but if you
unscrew it and take it to a computer store, I'm sure that they could
find one that will work. It should be very easy to find an adapter or
just a fan that would work.
The L7mm3 is a very low end motherboard and so its cpu fan is probably
low end also.
I believe that the pro3200 is really an Athlon XP1900+, but I'm not
sure.
The cpu is 'soldered' to the motherboard. This was most likely done to
save the price of the 'socket'.
This also means that you cannot replace the cpu itself (unless you are
really talented).
