LA3a tech help needed
Bradw764
I have an LA-#A Urei that doesn't have a bias pot. T4B was bad. Replaced several 10uf caps and now my bias voltage is at 23 volts. Before changing caps it was at 13.5. Also when I turned the limit pot all the way up, the meter would peg and I would get a bunch of hum. The unit is passing signal but no compression. Is this a different version? must be. Thanks for any infp. Brad
Thanks for the advice. Any reasom bias voltage jumped up? Why would the old T4B seem to react when the new Drip model doesn't? Shouldn't I be seeing A/C voltages? Have you seen one like this with no bias pot? I will get ALL caps done. Thanks again!
