Lacie ms35u3 hard drive dropped
dave5246
Hi TH. I just dropped the lacie HD not very high from the floor and it hit where the usb connection is, it still powers on but wont connect to the pc. Is there a way of fixing the connection? i cant see any screws. Do ppl on here think its the connection given that it still powers on?
Any help greatly appreciated
Hey there, Dave!
Unfortunately a drop like this could have damaged the internal particles of the drive itself.
Do you hear any unusual noise coming from the drive when you connect it?
Do you see the drive in Disk management on your computer? Can you share a screenshot of it?
You can also check if your drive has a hardware encryption or not, if it doesn't you can get it out of the enclosure and connect it directly to your computer through a SATA port. It might let you access it.
If it is in fact a physical damage, we won't be able to troubleshoot it. Which basically leaves you with contacting a professional data recovery company for assistance and retrieving of your files. Other than that, I'm not sure you will be able to fix the...
Hey there, Dave!
If it is in fact a physical damage, we won't be able to troubleshoot it. Which basically leaves you with contacting a professional data recovery company for assistance and retrieving of your files. Other than that, I'm not sure you will be able to fix the physical damage easily and without a professional help. 🙁
Hope this helps though. Good luck!
SuperSoph_WD
