Lagging, buzzing sound, stuttering sound
dasnawq789
8
I'm using my laptop for almost a year
Then this problem suddenly comes up, whenever I'm playing music or video there is a buzzing stuttering sound and the music or video become laggy
but when i restarted my laptop this problem dissappear, and when I have played my laptop for 10 hour(less or more) this problem comes again, then i just restart my laptop again, the prob dissapear
Here is my Laptop spec :
Core i7 3630QM
Nvidia GT650M 2GB
Memory 8GB DDR3
Hardisk 1TB
Win 7 64-bit
Lan2u
114
18
It is possible it is just your RAM filling up next time it happens check and see what % is not being used.
dasnawq789
8
my ram only used 41%
Lan2u
114
18
Have you tried running an antivirus scan?
plaintuts
Admirable
May 5, 2014
2,857
386
it may also be static interference from the a/c adapter.
try using a power outlet that uses the 3 pronged socket "the one with the ground lead/prong" for the a/c adapter.
dasnawq789
8
thanks all
found the problem, there is nvstreamsvc.exe that was causing this problem whic is coming from Geforce Experience
seems like this application was having error issue
Similar threads
