Question Lahptop overheat and power off
May 26, 2019
Hi,
My laptop is Dell Inspiron 15R SE 7520 .
It gets heated and power off after some time(after some load). I have tried to collect heat info and attaching here. Please advise if I should change cooling fan or it is only thermal paste or both or other issue.
Thanks
R_1
Judicious
Herald
my girlfriends laptop overheated something awful, I took the bottom off and removed a piece of what looked like felt from one of the exhaust fans, her cats shed enough to plug the exhaust. may not be the issue but it has caused high temps in the past. check the exhaust airflow. thermal paste may indeed need to be installed the i7 3832 is old enough the stock paste may be failing.
