I'm not very wise when it comes to voltages, watts, and amperage.
My question is, how many Corsair SP120 High Performance Edition fans can i connect to a single 30 watt channel on a Lamptron FC8.
I'm sure this is dead wrong, but based on an amperage of .18A @ a max fan voltage (12V) is that really only 2.16 watts consumed by an SP120 at 12 volts?
I ask because I'm going to be using a Corsair 900D, and I will have 2 Switftech MCR420 XP's in push pull, with 5-6 other case fans. I want to operate 4 rad fans on one channel if possible.
Please let me know the max amount of Corsair SP120 High Performance Edition fans I can use per channel considering maximum output.
Lamptron FC8 - http://www.lamptron.com/product/controllers/fc8/
Corsair SP120 High Performance Edition - http://www.corsair.com/us/cpu-cooling-kits/air-series-fans/air-series-sp120-high-performance-edition-high-static-pressure-120mm-fan.html
Thanks in advance!
MADAO
Thanks in advance!
MADAO
