Guys I need help. I was switching out graphics cards for some testing and while I was putting my card back (ie test card MSI 7770 -> MSI 660ti) I forgot to turn off the cpu mains (the computer was shutdown but I forgot to turn it off from the mainboard/power-wall socket) .
The CPU is running fine and everything is running fine but the onboard LAN doesn't want to work at all. The lights aren't turning on on the back of the motherboard.
I have tried different cables/slots on the router.
I have tried switching my computer and all other related devices off (isolating it from any power for 1.5 hours)
I think the LAN chipset got shorted due to static or something but there is something I can't understand, the LAN controller (broadcom) is showing in the device manager and if I uninstall it and refresh the device manager it is detected again.
But the LAN port doesn't seem to work with the cable in it (inside windows or in the bios, asrock z77 extreme 6) I don't think reinstalling windows would do anything as its not working in the bios either (in the chipset diagram it shows that the LAN port is disconnected)
Any help/advice on what I should do? I know RMA is the best option but I don't have a backup setup to fall to, plus RMA will take a long time.
I could simply buy a NIC and put it on the motherboard but I guess that'll kill the resale value.
Suggestions?
Thanks in advance!
Suggestions?
Thanks in advance!
