I've been having issues with my LAN, mainly the fact that it'll work for maybe a minute or so when I turn on my computer, but after that it thinks that my network cable is unplugged. I know for a fact that that cable works, because I've swapped it with a cable from one of my other computers and they both work perfectly fine on my other comp. I'm able to disable my connection and then reenable it, and it works again, but again only for a moment.
This is starting to get extremely annoying, as I've tried to reinstall the drivers multiple times and with limited success. Originally, I would be unable to get the device working again once it was disabled. However, after installing the drivers off Gigabyte's site, I'm now able to properly disable and reenable the device.
Any have any insight? Should I try updating my bios or fiddling with the settings or something? It's getting real annoying having my internet drop out every couple of minutes.
Network Card: Realtek built-in NIC card
Motherboard: GIGABYTE GA-880GMA-USB3
OS: Win 7 x64
OS: Win 7 x64
