Trying to setup a LAN gaming session for “Anno 1404 Venice”... I had it working in the past with direct Ethernet connections but we have since added an Ethernet-less laptop and therefore using wi-fi. When either machine hosts, the other cannot see the game in the lobby.
Machines:
Wireless router/switch and modem: Hiltron CGN2-ROG
Device1: Windows 7 machine connected directly with Ethernet
Device2: Windows 10 machine connected via wi-fi (no Ethernet port)
Configurations:
-firewalls and antiviruses turned off for all machines including router
-Home Network, HomeGroup: Joined, Connections: Local Area Connection.
Observed behavior:
1. Both computers are on the same sub-net and can ping each other.
2.Can share files through the home group.
3. When launching the game and attempting to host/join games: From Client machine appears to properly broadcast and get a response from the host machine. However this game session does not appear in the in-game join screen, just empty. No further network communication appears to occur.
wireshark:
Source:192.168.0.16 Dest: 192.168.0.15 Protocol:UDP
INFO: 9100 → 9100 Len=272
Source:192.168.0.16 Dest: 192.168.0.15 Protocol: UDP
cmd:
\Users\Michael>netstat -na | find "9100"
UDP 0.0.0.0:9100 *:*
If any more details are needed I would be happy to provide.
Any suggestions or fixes would be greatly appreciated,
Michael
UPDATE:So I just picked up a DLINK DIR-819, set up the LAN the same way and everything worked fine. So indeed seemed to be an issue with the Hiltron router.
I only investigated the IPs... if the MAC addresses were wrong how would I go about correcting that?
Machines:
Configurations:
Observed behavior:
wireshark:
cmd:
Michael
