LAN is not detecting TOSHIBA Sattelite C50
Ravshanbek
Commendable
Jun 20, 2016
5
Hi everyone,
Suddenly my laptop is not detecting LAN. Device manager is not showing LAN adapter.
I have run devmgmt.msc. In Network Adapters group there is nothing with label of LAN Network Adapters.
OS is Windows 8.
Thanks in advance.
Sincerely,
I had this problem in my laptop , and solved it by powering off the device , remove the battery for 5 minutes then install drivers (if not installed already)
First of all, thank u for ur answer.
U r right, there is a component with a label Realtek PCIe FE Family Controller.
By properties, it is working properly.
Unfortunately, LAN still is not working.
Thanks for answer.
I will try later and be sure to post.
Hi everyone, and who answered me and thanks for ur attention.
After zizoux07 suggests, I'd tried to remove battery for 5 min. Unfortunately nothing was happened.
In Network Connections window, Lan was not appeared. After some time (exactly I don't know, maybe after 10 days) I've realised that Lan label was appeared in Network window, and after some time it's dissappeared again, and so on.
At the end, I could not understand what the problem it was.
But I thank all members who answered and read this post.
