LAN network unidentified. + No internet/ intranet!! HELP!
lilpopjim
167
Hi!
My issue i'm having at the moment is that i can't connect to the internet nor can i connected to my home 's intranet LAN network. It's very frustrating.
Here is how the problem raised.
I turned on my computer on Monday to find that i got the Black Screen Of Death (Black screen with only the cursor after logging in to account)
I booted into safe mode. Run several virus scans with multiple programs (Avast, Spybot S&D and Malware Bytes) as i hear the Black SOD is caused by malware. I found no threats. I couldn't use AVG or Kaspersky as they need an internet connection to update to most recent version, not helpful as i need an uptodate database!
I also tried booting into safe mode with networking. This did not work. So i felt that there was a networking issue. I then booted into safe mode and disabled ALL network adapters including Hamachi and nvidia nforce networking controller. After doing so i booted normally and i got hold of my computer again! got past log in screen. the lot. I Have also noticed that my computer is slower than it was the day before. And it hangs for several minutes on the 'shutting down' screen.
I have re-enabled networking controllers and reinstalled drivers for the nVidia nforce network controller. (i have also noticed a lacking of networks adapters in the device manager compared to what was present before disabling all network adapters/ controllers.)This did not work.
I tried pinging my router. And other computers, this didn't work.
I also tried 'ipconfig /renew /release' command prompts and windows timed out connecting to some adapters.
While typing command 'Ipconfig /all' i noticed that there was a lot of information which i feel that shouldn't be there!! (I'm at school at the moment, i will post information found in CMD prompt
I tried 'CHKDSK /C /R' I recieved no errors
I manually inputted the i.p. DNS & suffix mask address, nothing is working!
I'm really stumped with what to do! Can someone please help me!
Thanks in advanced. Lewis
Well you have several possibilities here that could be the problem. First off, is there another computer connected to your router/network? What are you connected to a router, modem etc.. This is a wired connection I would assume ethernet not wireless? When you do a ipconfig/all do you get a valid ip address or something like: 169.xxx..xxx.xxx if you get a 169 ip address then whatever you are connecting to (IE router, cable modem, dsl) is not broadcasting DHCP correctly. If you are getting a valid IP address 192.168.xxx.xxx this is an inside IP address which is coming from probably your router. Anyways try to ping your gateway which should be under the same subnet (a whole other subject). Essentially try those things and tell me what you get when you run ipconfig/all. Himachi could be causing issues as well just for reference maybe uninstall that too.
Report back with more information and hopefully we can help you out.
i was planning to clean install when the new ivy bridge cpu release. but for now i think its too much to sort out. i have AS EXAMS in a month, and ill keep your idea in mind
Okay buddy! Heres the whole ipconfig/all information.
Windows IP Configuration
Host Name . . . . . . . . . . . . : lewis-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Hamachi:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Hamachi Network Interface
Physical Address. . . . . . . . . : 7A-79-05-65-8D-69
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2620:9b::565:8d69(Preferred)
Link-local IPv6 Address . . . . . : fe80::e8a6:fcb8:2f79:3328%17(Preferred)
IPv4 Address. . . . . . . . . . . : 5.101.141.105(Preferred)
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Lease Obtained. . . . . . . . . . : 28 March 2012 17:18:09
Lease Expires . . . . . . . . . . : 28 March 2013 17:20:19
Default Gateway . . . . . . . . . : 5.0.0.1
DHCP Server . . . . . . . . . . . : 5.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 310016452
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-10-72-B5-8D-00-22-15-2A-D3-11
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-1D-60-0B-FF-1E
Link-local IPv6 Address . . . . . : fe80::6c6e:91ff:3ca9:233%2(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.2.51(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
DHCPv6 IAID . . . . . . . . . . . : 234889749
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%2
fec0:0:0:ffff::2%2
fec0:0:0:ffff::3%2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{87A0404B-E746-4987-9F0A-1CEEEA6FD265}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter isatap.{EAFDA93C-A09D-444F-99A8-AF885708988E}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #34
IPv6 Address. . . . . . . . . . . : 2002:565:8d69::565:8d69(Preferred)
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users\lewis>
For example the DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
The following numberical/ alphabetical sequences doesn't seem right with me, am i correct?
And you are correct, i'm conecting via cable, and as you may ahve noticed, all of the adapters except the nVida nforce controller have 'DHCP Enabled' set to no.
I'll uninstall Hamachi now for you.
Also as a previous user has said, i tried 2 other cables. Nothing happened.
Thanks for the help!
Yes, Himachi does lots of odd things compared to just troubleshooting a regular network. Not sure what you were using it for as it kind of creates a tunnel or VPN (virtual private network). Definitely turn it off or un-install it before we go troubleshooting any further. Then run an ipconfig/all and repost results. Also you never answered any other questions as is this the only PC having problems? Do you have a router or connected straight to cable/dsl modem etc... so we can determine if it is just your computer or possibly your ISP (internet service provider) or a router which is yours etc.
Yeah sorry i was in a bot of a rush at the time when i first answered you. I use Hamachi to connect fo friends to play 'LAN' games etc for a bt of fun etc. And i've also uninstalled Hamachi. And yeah i have a router. It's an AOl router which was provided not that long ago. Never had problems since i got it. And i have another desktop wired and 2 laptops connected wirelessly. 3 smartphones and my tablet are also connected wirelessly. They all get perfect siganl and an internet connection.
Heres the updated config.
fec0:0:0:ffff::2%2
fec0:0:0:ffff::3%2
Can you copy another ipconfig /all output from another computer?
Do you have fixed IP set in IPv4 settings?? (I see the "Preferred" address is being set, but the gateway is empty.) What happens if you set it to automatic?
That address means you aren't getting an IP address from the router like you should. If you do an IPCONFIG /RENEW from a command prompt do you get a different IP address. Does the port on the router where you are plugging the cable from your PC show a link light?
This the the config from the second desktop pc. (which i am using at the moment)
Host Name . . . . . . . . . . . . : Family-PC
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Wireless PCI 802.11b/g adapter WN4201B
Physical Address. . . . . . . . . : 00-30-F1-BA-0A-4B
Description . . . . . . . . . . . : VIA Rhine II Compatible Fast Ethernet Ada
pter
Physical Address. . . . . . . . . : 00-16-E6-D3-98-A8
Link-local IPv6 Address . . . . . : fe80::c479:18ba:e6f2:4165%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.5(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 28 March 2012 18:24:11
Lease Expires . . . . . . . . . . : 29 March 2012 18:24:11
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 234886886
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-A8-2F-B5-00-16-E6-D3-98-A8
DNS Servers . . . . . . . . . . . : 192.168.1.1
192.168.1.1
Physical Address. . . . . . . . . : 7A-79-05-3E-79-8C
IPv6 Address. . . . . . . . . . . : 2620:9b::53e:798c(Preferred)
Link-local IPv6 Address . . . . . : fe80::5c84:387f:d617:2b18%16(Preferred)
IPv4 Address. . . . . . . . . . . : 5.62.121.140(Preferred)
Lease Expires . . . . . . . . . . : 28 March 2013 18:26:18
DHCPv6 IAID . . . . . . . . . . . : 410679671
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.{C970C5D3-4ABA-4A23-B7D4-136E02BC4972}:
Tunnel adapter Local Area Connection* 9:
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:2870:36c:3f57:fefa(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::2870:36c:3f57:fefa%12(Preferred)
Tunnel adapter isatap.lan:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{66DF84B0-9B0F-41D3-BA9D-F908F18BB47E}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
And yes the green LED on the router is lit up
Hi, sorry what do you mean?
@jim_L9
As said the LED is lit on the router, it's also orange/ yellow on seperate led's on the socket on the motherboard.
And yes i have tried that. It comes up with the following error.
C:\Users\lewis>ipconfig /renew
an error occured while renewing interface local area connection : unable to contact your DHCP servre. REquest has timed out.
An error has occurred while releasing interface loopback Pseudo-Inteface 1 : the system cannon find the file specified.
Sounds like you have a rootkit best way to clean these rootkits is to get an emergency boot cd AV like kaspersky or bitdefender boot off the cd and clean your machine make sure a lan cable is plugged in.
Another reason for black screen of death is you hard drive could have a bad sector or corrupted system file to fix this in windows 7 go to the repair option then select command prompt and make sure you are on c: drive and type chkdsk /r
If you can't get to repair option in windows 7 then the you a windows 7 repair cd it can be made on any system that has windows 7 installed.
ahh okay. you also just reminded me that my friend gave me a me a windows 7 cd today. ill try the repair functionn and chkdsk again. said i had no bad sectors but something could of changed. thanks for the suggestion. ill make a boot cd right away!
Edit: I also have a painfully slow download speed.. I live in the country side.
the router supports up to 32 Devices. as ive said ive never had problems with this router.
router model: EchoLife HG532
Either malware/rootkit took out your TCP/IP stack, or there is a problem with DHCP on your router. If you open the properties of your network connection (Local Area Connection most likely) under "This connection uses the following item:" what is checked/unchecked? Try unchecking everything except Client for Microsoft Networks and TCP/IP v4 and click OK, then reboot or run ipconfig /renew from the command line. If that doesn't work, disable/uninstall any antivirus or firewall software that has a firewall. It's possible (but not likely) that it could be blocking DHCP requests.
I see. I was going to suggest that you set it manually to something like this:
IPv4 Address: 192.168.1.100
Subnet Mask : 255.255.255.0
Default Gateway: 192.168.1.1
DNS Servers: 192.168.1.1
But if you tried that already, then I think I'm out of ideas.
@extremepcs
I tried what you said and rebooted and performed /renew nothing changed. I'm so confused!!! I'll unsiall all antivirus etc after i've mounted a emergancy boot cd as suggested by TechGuy (thanks)
@szaboaz
I did ry it, yes but i'm new to the whole intternet diagnostics and customising of setting's etc. But the addresses you suggested are different from mine, i some what guessed them by using cmd prompt as a guide. I'll use yours, then will try the boot cd as said. I will then post results.
Thanks for the help so far guys/ gals. Much appreciated!!!
