Hello Community,
Building a new computer and I don't have a fan splitter. I'm currently using a Lian li Lancool ii mesh (performance) along with a Kraken X53 aio. My problem is the two 120mm fans on the kraken don't reach the bottom of the case where the fan headers are and I don't currently have a splitter. The aio is top mounted, left aligned. So without a splitter I can't connect them to the motherboard.
The case does come with a fan controller hub and I do have two free 4 pin fan ports left on it. The fan hub is controlled by a sata cable. My question is would there be any issue since I don't currently have a splitter could I just use the fan hub on the case for the aio 120 mm fans? It seems to be the only solution to my dilemma at this time. My mobo is a Mag Tomahawk x570. The older Kraken used to come with a splitter but they don't anymore.
Any help would be appreciated.
Resolved:
Works more than fine with the fan controller that came with the Lian li Lancool ii mesh (performance) case.
Regards,
Malakai
Resolved:
Regards,
Malakai
