[SOLVED] LANCOOL II Mesh: Radiator top of front?
Prem Sawari
85
I got the Lancool II mesh in white and have my parts ready for my 3080 build this week.
I ordered a 360mm radaitor and wanted to do a front radiator setup with push/pull.
I've been looking online but haven't seen any front radiator intake setup, only top.
Would this be a problem with the RTX 3090?
Should I cancel and get a 240mm instead or can I do the 360mm configuration?
This page shows the recommended radiator/fan possible combinations. It looks like as long as your fans and radiator are not thicker than 110mm you should be OK.
