Lapping Cooler Master Hyper 212+ question
cory1234
628
Yeah, I've heard that too...but not with this exact model. I heard the bottom of this heatsink is not very flat. What about a little bit of lapping? Does anyone have any experience with this particular heatsink?
I lapped my original Thermalright Ultra 120 and my cpu. The Thermalright 120 has the copper pipes inside a base so no problem. The only reason I did it was to see if an old fart like me could do it. Results were excellent.
Lapping exposed copper heatpipes is not a good idea. The pipes are constructed of very very thin copper.
Installing a second fan for a push-pull effect may or may not be worth it. Typically the temperature will drop less than one degree with a second heatsink fan. Results will vary depending on the configuration.
