Laptop battery charger question
For a gaming laptopt, it's usually better to get the original charger, as they can suck a lot of power sometimes. I wouldn't recommend a generic one.
Keep in mind that I'm one to get a different laptop's charger, cut off the end connector and solder in the correct connector, and use it like that. Ugly and not safe.
And even though, I'm still telling you not to go with the generic one. I don't think they're safe for your laptop.
That said, the charger you were looking at will almost certainly work with your computer, so you can buy it. Not recommended, but it will work, and you might even not have any kind of issues.
