Question Laptop battery charging and discharging. working only without battery.
snatchysquid
76
Hello!
I have an hp laptop which wont turn on and charge. When the laptop was still alive once I connected the charger to it it would start charging and discharging and at the end wont add any % to the battery.
Once the charger is connected the light next to the charging port becomes white and then immediately orange and then it turns of and on endlessly,
I opened the inside of the laptop and took out the battery and connected the charger, everything works.
So the laptop works only without the battery.
I still need a battery because using the laptop without a battery is not a good option.
Is the problem in the battery or the motherboard? How can I fix the problem and do I have to buy a new component?
This is the laptop:
hp 15-da0008nj
This is the battery:
HT03XL Battery For HP
Thanks for helping!
