[SOLVED] laptop battery drains after shutdown
nishicant
Commendable
Aug 18, 2018
i have asus rog strix scar 2 laptop. my laptop battery drains to zero after shutdown even if it's fully charged. what could be the reason?
Reactions: OPTIMUSv
There might be an issue with the battery itself. How old is the laptop? You could try and see if the laptop has any BIOS updates pending and if your OS also needs an update(we're on Windows 10 version 20H2) to see if that resolves the issue with battery drainage but a failing battery cannot be saved no matter what OS and BIOS updates you perform. For the latter, you're going to need a replacement battery.
