G GamerX23 Honorable Nov 18, 2013 49 0 10,530 Jul 23, 2017 #1 I have an Acer E5-575G laptop and I'm planning to replace my battery, is it possible to get a battery that has a bigger capacity than the battery that I already have in my laptop? By the way my battery is non-removable.
Solution webworkings Aug 4, 2017 Technically all batteries are removable, however how 'easily' they can be removed is a whole other story. And in regard to the capacity of the battery, as far as I can find there is no larger capacity one you can use.
webworkings Titan Apr 6, 2016 11,201 0 86,610 Aug 4, 2017 Solution #2 Technically all batteries are removable, however how 'easily' they can be removed is a whole other story. And in regard to the capacity of the battery, as far as I can find there is no larger capacity one you can use. Upvote 0 Downvote Solution
