Question Laptop Cooler Problem.
Jan 13, 2020
8
What if my cooler sounded like some kind of "chainsaw" then fixed and sounds a bit weird but not so loud. The games are running kinda bad and after some time the cooler starts working and sounds a bit weird as mentioned but the game performance improves a bit. The air flow doesn't feel coming out anymore so it's overheating because it doesn't work anymore at its maximum power, just barely i guess. Overheating means that the CPU can't run at its maximum power aswell, and that's the problem of my fps issues?
Jan 13, 2020
8
they did clean it up without holding the fans from spinning so bearing on it could be wear out bring it back and ask them now why you system does this since cleaning .
It probably broke a bit because of them and because it is like 5 years old or something. Also the frames problems come from overheating, right?
