Laptop CPU or motherboard issue?
TheNostalgicOS
63
Hello so I have a dell vostro 1520 and I was wondering what was wrong with it because when I turn it on the lights come on but no display so I looked at the manual and it says that its a system board error, but I am unsure if its a mobo or CPU issue as on the manual it says both.
So how do I see which one is at fault?
Thanks!
Try this...
1. Turn the laptop off (not sleep or hibernate but off).
2. Connect an external monitor to the laptop.
3. Turn on the external monitor.
4. Turn on the laptop.
NOTE: You may have to press an "external monitor" button. Could be the f4 button or a button with two monitors on it, for the external monitor to work.
If you can see fine on the external monitor, then your attached display, or the ribbon cable that connects it, are your problem.
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be replaced.
You may also want to try hitting CTRL + SHIFT + WIN + B to try and reset your graphics driver as another possible fix.
Hmm I think I might try that thanks!
