Laptop model: MSI GF75 Leopard 10UEK
specs:
rtx 3060 75watt,
i7-10750h, clocked down to 3.6ghz,
32gb ddr4,
Windows 11
i am capable of replacing the battery, provided that its even possible with this model, i don't see anything really on google about replacing these batteries. i'm thinking its the charger for the laptop that is the problem, about 3 times now i've had the laptop die while plugged in, i turned it back on after a few minutes and saw the battery percentage dropped like 65% so it kind of looked like the charger couldn't keep up. but then i saw the battery wear level so i wanted to see what someone else had to say about this.
Temps are being monitored and absolutely no issue with temps. about 58 degrees for CPU, 48 degrees for the GPU.
The laptop was a display unit from Staples, so i don't know if the charger is the original or not. i have only had this laptop for a few months. any help is appreciated, if i missed anything sorry ive been up all night looking at memes. super tired.
specs:
rtx 3060 75watt,
32gb ddr4,
Windows 11
