Laptop display problem
When i turn on the laptop it turns on but every time i turn it on after almost a fixed time my screen starts to flickerand it gradually turns to partially visible white screen and finally complete white screen.
Can some one help me asap
Its lenovo ip 320
https://ibb.co/dV7xPp
Try this...
1. Turn the laptop off (not sleep or hibernate but off).
2. Connect an external monitor to the laptop.
3. Turn on the external monitor.
4. Turn on the laptop.
NOTE: You may have to press an "external monitor" button. Could be the f4 button or a button with two monitors on it, for the external monitor to work.
If you can see fine on the external monitor, then your attached display, or the ribbon cable that connects it, are your problem.
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be replaced.
I contacted lenovo technicians and they accessed my system and tried to solve it which means they got a display of my laptop on their system.
Does that mean it is working with external monitor
