C Caleb1108 Reputable Nov 15, 2014 61 0 4,630 Jul 2, 2016 #1 ok so I've looked and looked and i can't seem to find an external battery. my laptop is an Acer aspire v5 122p 0889, What form fatter hard Drive do i need. 2.5, 3.5 Thanks for the help.
Solution hang-the-9 Jul 5, 2016 Are you looking for an external battery or a hard drive? I'd guess you want a power brick vs something like a large UPS, something like this https://www.amazon.com/Naztech-PB15000-Universal-Charger-Extended/dp/B007URKIGC Check for compatibility with your laptop with them.
hang-the-9 Titan Mar 25, 2010 60,387 1,081 152,940 Jul 5, 2016 Solution #2 Are you looking for an external battery or a hard drive? I'd guess you want a power brick vs something like a large UPS, something like this https://www.amazon.com/Naztech-PB15000-Universal-Charger-Extended/dp/B007URKIGC Check for compatibility with your laptop with them. Upvote 0 Downvote Solution
C Caleb1108 Reputable Nov 15, 2014 61 0 4,630 Jul 5, 2016 #3 hang-the-9 : Are you looking for an external battery or a hard drive? I'd guess you want a power brick vs something like a large UPS, something like this https://www.amazon.com/Naztech-PB15000-Universal-Charger-Extended/dp/B007URKIGC Check for compatibility with your laptop with them. Thanks just what i needed. Upvote 0 Downvote
