laptop fan problem
samtiba
so i have an Acer Aspire E1-571G with NVIDIA 710M and it started overheating, so i disassembled the laptop, cleaned the vents, took out the fan, teared apart and cleaned it and now it turns smoothly in hand.
But the laptop is still overheating for some reason and there's a little airflow from the side vent and the fan makes a non-constant turning noise (like putting your foot on the gas pedal and releasing it every second)
so .. is my fan dying ?
Hi,
Yes you might want to consider replacing the fans with the exact one what the laptop has but first try reapplying a fresh thermal compound as well to the graphics card and the CPU that would help also in cooling down your laptop. Lastly, install the latest driver as well for your graphics card found in this link: nvidia.com/download/index.aspx
