Hello, so I am not the least tech savvy person on the planet but I am in need of assistance. My laptop has for a while been freezing, usually it occurs after playing a game for one hour or so. Rarely, but sometimes the freeze occurs when I am simply browsing the internet or watching a video. My laptop is only about half a year old, so I don't believe this should be happening at all. My laptops statistics are:
-cpu: i7-6700HQ
-gpu: nvidia 970m
-ram: 16 gb
-1 ssd and 1 hdd (the game is installed on this harddrive if that matters)
I believe this is all the notable information that should be provided. Also, I use obs studio when playing my games, I don't believe this started happening after using obs though, so I don't believe that to be the case. Overheating could be an issue but both fans are working properly and are clean, and I also have a laptop cooling fan beneath it as well for good measure. The bottom left hand portion of the keyboard does heat up a bit when the fans aren't on duty (I believe it is either the gpu or the cpu for I am unsure of what my fans copper wires are attached to). I purchased the laptop from cyberpowerpc and have sent it to them under warranty. They wrote to me in an email when I asked what they had done to solve the issue. They replied "We reloaded windows and tested the system using PRIME 95 to stress test the CPU so as to recreate the issue. System no longer freezes." Since I am writing this post, the problem is still quite clearly there. I have done as much as I believe I can do as a user, I have had someone who is much more competent, when it comes to stuff like this, look at my computer before I had sent it back for warranty.F He couldn't figure out the problem, he said the bios "may" have needed to be updated, but according to cyberpower things like bios or firmware should still all be up to date. I am at a loss, and am open to any suggestions I may have not yet encountered, if you know what's wrong I would be grateful to know the solution. Thank you for reading this far and another thank you in advance if you answer.
TL;DR: Computer is freezing. I don't know why. Please help!
I should note that I'm unsure if this is even in the right category for asking this question, apologies in advance if it isn't.
EDIT: I must do a hard reset via the power button, to get out of the freeze. I have reinstalled the OS on the SSD wiping it clean(cyberpower seems to have done the same seeing as how things were missing from the computer like the screensaver and some stored pictures, so make that twice), although the HDD remains untouched.
-cpu: i7-6700HQ
-gpu: nvidia 970m
-ram: 16 gb
