Recently, i dropped my laptop, after i dropped it, it takes a good 1 minute for a chrome window to open, and my FPS in games went from 100-150 to 20-30, What could i possibly have broken?
You probably damaged or detached the CPU cooling system from the CPU. Let's check to see if it's thermal throttling. Go to userbenchmark.com and run the test. Post your results here.Recently, i dropped my laptop, after i dropped it, it takes a good 1 minute for a chrome window to open, and my FPS in games went from 100-150 to 20-30, What could i possibly have broken?
May have damaged the GPU and now you can only run on integrated graphics.You probably damaged or detached the CPU cooling system from the CPU. Let's check to see if it's thermal throttling. Go to userbenchmark.com and run the test. Post your results here.
