Question Laptop is not powering on, help
May 30, 2022
18
Umm the laptop is not turning on, I checked the battery indicator, it's constant white light when I plug in the charger, so battery is full. But the other light indicator with a power button sign next to it, is turning on and turning off, and with it the hard drive is spinning and then spinning down to shut down again. I think it's a hard drive problem
What laptop do you have?
Are the battery and HDD removable?
Sorry for late reply, but the problem is over, I tested the hard drives in another system to see I it working, it works. But when I plugged it back in the laptop, I tried to turn it on again, and the same problem, but suddenly while the hdd was spinning and shutting down, spinning and shutting down, the screen lights up and blue screen of death, it says "something wrong happened and the computer needs to be restarted, we'll restart it for you", then restart happens and it works... Somehow. I think it was a battery problem, the battery's been misbehaving for a while. Anyways, thanks for replying!
Reactions: lvt
