Question Laptop keeps showing bluescreen every 30 minutes with DRIVER_POWER_STATE_FAILURE ?
Parroty69
Commendable
Oct 27, 2021
240
7
1,595
Laptop model: MSI GE72VR 6RF Apache Pro
CPU: Intel 6700HQ
RAM: 16GB DDR4 SODIMM
GPU: GTX 1060
Drive: 1TB HDD and 256GB SSD
OS: Windows 10
I've been getting bluescreens for a long time now and they happen every 30 minutes. Sometimes they happen while I'm coding and I nearly lost hours of work if it wasn't for autosave that rescued me. It's happened 3 times today and I get really worried if I've lost my work.
Here are the past 3 memory dumps that've happened today:
https://drive.google.com/file/d/1cRbVLaEW6WnvK6IDYfDsvGSBCR2G4oAV/view?usp=sharing
Please let me know if you've seen anything.
I thought it might say this
File: 123023-65359-01.dmp (Dec 30 2023 - 15:34:54)
BugCheck: [DRIVER_POWER_STATE_FAILURE (9F)]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
Probably caused by: dxgkrnl.sys (Process: chrome.exe)
Uptime: 1 Day(s), 1 Hour(s), 10 Min(s), and 54 Sec(s)
File: 123023-36562-01.dmp (Dec 30 2023 - 16:44:56)
Probably caused by: dxgkrnl.sys (Process: System)
Uptime: 0 Day(s), 0 Hour(s), 25 Min(s), and 50 Sec(s)
File: 122823-39718-01.dmp (Dec 28 2023 - 14:12:10)
Probably caused by: pci.sys (Process: csrss.exe)
Uptime: 0 Day(s), 0 Hour(s), 11 Min(s), and 23 Sec(s)
Jun 24 2023nvlddmkm.sysNvidia Graphics Card driver http://www.nvidia.com/
The nvlddmkm.sys file is a NVIDIA graphics card driver. There are a few things you can do to fix this problem. First off, try a full uninstall using DDU in Safe Mode then re-install the driver (more information). Or try getting the latest version of the driver. Or try one of the 3 most recent drivers released by NVIDIA. Drivers can be found here: http://www.nvidia.com/ or you can allow Windows Update to download the driver for you, which might be a older/better version.
report - mostly for me
This particular bugcheck (0x9F with argument 1 set to 0x3) is quite easy to debug when you know how, so for the benefit of others following this thread, here's how...
This bugcheck happens because a device failed to complete a power transition (from low to high power, or vice-versa) in a reasonable time. The bugcheck data gives us two important addresses; in argument 4 we have the address of the IRP (interrupt request packet) that is managing the power transition, and in argument 2 we have the address of the device object that Windows uses to manage the device having the problem...
Code:
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: ffff938887bc9630, Physical Device Object of the stack
Arg3: ffff92036bc47ba0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffff93888c063620, The blocked IRP
Examining the IRP we see the following...
Code:
2: kd> !irp ffff93888c063620
Irp is active with 6 stacks 4 is current (= 0xffff93888c0637c8)
 No Mdl: No System Buffer: Thread 00000000:  Irp stack trace.
     cmd  flg cl Device   File     Completion-Context
 [N/A(0), N/A(0)]
            0  0 00000000 00000000 00000000-00000000
            Args: 00000000 00000000 00000000 00000000
 [N/A(0), N/A(0)]
 [N/A(0), N/A(0)]
>[IRP_MJ_POWER(16), IRP_MN_SET_POWER(2)]
            0 e1 ffff938887bc9630 00000000 fffff807314afd70-ffff92036bc1f778 Success Error Cancel pending
           \Driver\pci    dxgkrnl!DpiFdoPowerCompletionRoutine
            Args: 00000000 00000001 00000001 00000000
            0 e1 ffff938889aa7030 00000000 fffff8071a37ac60-ffff93888dd33728 Success Error Cancel pending
           \Driver\nvlddmkm    nt!PopRequestCompletion
 [N/A(0), N/A(0)]
            0  0 00000000 00000000 00000000-ffff93888dd33728
At the bottom there are the drivers that are holding on to the IRP because the power transition isn't happening properly. We see pci.sys, the Windows root PCIe driver (which is not at fault because it's a Microsoft driver) and below that we see nvlddmkm.sys, the Nvidia graphics driver which is the real cause of the problem (or the graphics card itself).
We can get more information by examining the device object...
Code:
2: kd> !devobj ffff938887bc9630
Device object (ffff938887bc9630) is for:
 Cannot read info offset from nt!ObpInfoMaskToOffset
 \Driver\pci DriverObject ffff938885be6960
Current Irp 00000000 RefCount 0 Type 00000023 Flags 00001040
SecurityDescriptor ffffe101681987e0 DevExt ffff938887bc9780 DevObjExt ffff938887bc9ec8 DevNode ffff938887bcb860
ExtensionFlags (0000000000)
Characteristics (0x00000100)  FILE_DEVICE_SECURE_OPEN
AttachedDevice (Upper) ffff9388874f26a0 \Driver\ACPI
Device queue is not busy.
The most useful bit of information in there for us is the address of the device node (the DevNode). This describes the actual device itself...
Code:
2: kd> !devnode ffff938887bcb860
DevNode 0xffff938887bcb860 for PDO 0xffff938887bc9630
  Parent 0xffff938887bf6ca0   Sibling 0000000000   Child 0000000000
  InstancePath is "PCI\VEN_10DE&DEV_1C20&SUBSYS_11D71462&REV_A1\4&343593a9&0&0008"
  ServiceName is "nvlddmkm"
  State = DeviceNodeStarted (0x308)
  Previous State = DeviceNodeEnumerateCompletion (0x30d)
  StateHistory[18] = DeviceNodeEnumerateCompletion (0x30d)
  StateHistory[17] = DeviceNodeEnumeratePending (0x30c)
  StateHistory[16] = DeviceNodeStarted (0x308)
  StateHistory[15] = DeviceNodeEnumerateCompletion (0x30d)
  StateHistory[14] = DeviceNodeEnumeratePending (0x30c)
  StateHistory[13] = DeviceNodeStarted (0x308)
  StateHistory[12] = DeviceNodeEnumerateCompletion (0x30d)
  StateHistory[11] = DeviceNodeEnumeratePending (0x30c)
  StateHistory[10] = DeviceNodeStarted (0x308)
  StateHistory[09] = DeviceNodeEnumerateCompletion (0x30d)
  StateHistory[08] = DeviceNodeEnumeratePending (0x30c)
  StateHistory[07] = DeviceNodeStarted (0x308)
  StateHistory[06] = DeviceNodeStartPostWork (0x307)
  StateHistory[05] = DeviceNodeStartCompletion (0x306)
  StateHistory[04] = DeviceNodeStartPending (0x305)
  StateHistory[03] = DeviceNodeResourcesAssigned (0x304)
  StateHistory[02] = DeviceNodeDriversAdded (0x303)
  StateHistory[01] = DeviceNodeInitialized (0x302)
  StateHistory[00] = DeviceNodeUninitialized (0x301)
  StateHistory[19] = Unknown State (0x0)
  Flags (0x6c0000f0)  DNF_ENUMERATED, DNF_IDS_QUERIED,
                      DNF_HAS_BOOT_CONFIG, DNF_BOOT_CONFIG_RESERVED,
                      DNF_NO_LOWER_DEVICE_FILTERS, DNF_NO_LOWER_CLASS_FILTERS,
                      DNF_NO_UPPER_DEVICE_FILTERS, DNF_NO_UPPER_CLASS_FILTERS
  CapabilityFlags (0x00002001)  DeviceD1, WakeFromD3
In the InstancePath above we can see the VEN & DEV identifiers for the actual device. If you look up VEN_10DE&DEV_1C20 you'll see it's your GTX 1060 (mobile). You can also see from the CapabilityFlags at the bottom that the device supports power state D1 and is capable of waking from D3 - these are the low power states, D0 is the fully on state.
Either the graphics card failed to power up properly or the driver failed in running the power up process. The version of the nvlddmkm.sys that you have installed is not current...
Code:
2: kd> lmvm nvlddmkm
Browse full module list
start             end                 module name
fffff807`45770000 fffff807`490c3000   nvlddmkm T (no symbols)
    Loaded symbol image file: nvlddmkm.sys
    Image path: \SystemRoot\System32\DriverStore\FileRepository\nvmiig.inf_amd64_3583fda5ef1eb1bb\nvlddmkm.sys
    Image name: nvlddmkm.sys
    Browse all global symbols  functions  data
    Timestamp:        Sat Jun 24 00:22:34 2023 (64960D1A)
    CheckSum:         0384EE9C
    ImageSize:        03953000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
    Information from resource tables:
The Nvidia driver website has a later driver (546.33) dated 12th December 2023. You might want to try installing that version. Be sure to do a clean install of the driver - via the Custom (Advanced) option.
That said, laptops often have their graphics drivers customised for power saving, operational, and/or performance reasons. Because the generic drivers from Intel (for the iGPU) and Nvidia (for the dGPU) do not contain these customisations they often don't work properly and/or cause BSODs. I would suggest you download the latest graphics drivers from the MSI website for your laptop model and use those in place of the generic drivers. They are guaranteed to be compatible with your laptop, so if it BSODs with those drivers then it's a graphics card issue.
Reactions: Colif
