Question Laptop keyboard not working, after opening it and cleaning dust
Lutfij
Did you reassemble the laptop in the reverse order of how you opened the laptop? If so, you should be able to reconnect the ribbon cables to the motherboard to regain it's functionality. On another note, did you try cleaning the keyboard's underside as well as all the keys? Can you elaborate on what you're seeing in terms of a keyboard not working? one key not working or that the entire keyboard isn't found n Device manager?
