R raphael44 Reputable Nov 30, 2015 1 0 4,510 Nov 30, 2015 #1 when I turn on my laptop it makes a loud beeping sound, how do I fix it?
thatmoney Distinguished Dec 26, 2013 184 0 18,710 Nov 30, 2015 #2 Does it boot up normaly? If not it's a bios beep code that you have to look up and depending on the beep it means different things. Upvote 0 Downvote
reedo_43 Splendid Feb 18, 2010 6,195 3 29,965 Nov 30, 2015 #3 I would start by re-seating the ram. If that doesn't work pull out 1 stick and try again. If that doesn't work, replace that stick and remove the other and try again. Good luck! Upvote 0 Downvote
