Question Laptop not connecting to monitor
Jan 1, 2025
9
Have a Lenovo Legion 5 laptop that has suddenly stopped connecting to an AOC monitor. Worked fine for a few years, just stopped working and cant figure it out despite spending quite a few hours tryinmg to sort it.
Windows 11 with a Nvidia GeForce GTX 1660 Ti
Monitor wont recognise that laptop and just says "no signal".
Heres what I'vew done so far:
Tested with another HDMI cable (still doesnt work)
Tested another laptop on the monitor (all fine)
Tested power lead (all fine)
Looked at Display in Device Manager (Nvidia GeForce GTX 1660 Ti driver showing as working fine, no issues)
Tried to cast the display to the monitor with Windows key & P (no joy)
Completely rebuilt Windows (still doesnt work)
Looked at HDMI port for physical damage (nothing)
Display working and playing games all fine on Laptop display (hints nothing wrong with GPU)
Any other suiggestions?
Both DP and HDMI
Can’t get it hooked up via the USB-C HDMI hub, but have just ordered a usbc to dp able from Amazon. Arrives on Friday so will try that.
Thanks for your help, will update when I receive the cable.
Just got the USB-C to DP cable through from Amazon, no joy. Still just showing "No signal" on the monitor.
Doing a bit of reading and some posts on Reddit indicate I'll need to use a USB-C to DP adapter and then a DP to DP cable to the monitor and then it'll work.
Some faffing about, this 😀😀
Now received a USB-C to DP adapter and hooked up to monitor via DP and still no joy - still saying "no signal" on the monitor.
Im now very perplexed - for the HDMI port to suddenly stop working is one thing, but for the USB-C to stop working at the same time is very confusing. Just cant see whats wrong here.
