Hey everyone I was hoping you could help me with a problem, I have the HP envy m6 1310sa laptop and I was in the Skyrim launcher and it says the listed GPU that it's using is my integrated gpu on the a10 apu (Radeon HD 8650G). I want to use both my GPUS (+Radeon HD 7600M) but I don't know how. I went into the catalyst control centre and it only lists the 8650G even under DUAL graphics. In device manager it shows both gpus and that both are working normally, does anyone know what I should do to enable it or even disable the integrated one through the BIOS. Don't really know what I'm doing as I'm scared I'm going to disable my display gpu and then I wont be able to see my screen. Help?
AMD A10 2.5 GHz
Radeon HD 8650G
Radeon HD 7600M
8 GB RAM
1TB HDD
AMD A10 2.5 GHz
Radeon HD 8650G
Radeon HD 7600M
8 GB RAM
1TB HDD
