N NewbieNub Reputable Feb 25, 2015 10 0 4,510 Feb 27, 2015 #1 So I accidentally dropped my laptop and my laptop port broke and I don't feel like getting a new laptop or go and repair it. Is there like a usb to power outlet or something that could help me.
uthvag Reputable Oct 5, 2014 1,115 0 5,660 Feb 27, 2015 #2 nope i think usbs are just for power output and not input and anyway you will damage your mobo even if you connect your cell phone charger to your mobo only solution is to repair the charging port Upvote 0 Downvote
N NewbieNub Reputable Feb 25, 2015 10 0 4,510 Feb 27, 2015 #3 uthvag : nope i think usbs are just for power output and not input and anyway you will damage your mobo even if you connect your cell phone charger to your mobo only solution is to repair the charging port oh 🙁 but thanks for the answer anyways! Upvote 0 Downvote
uthvag Reputable Oct 5, 2014 1,115 0 5,660 Feb 27, 2015 #4 NewbieNub : uthvag : nope i think usbs are just for power output and not input and anyway you will damage your mobo even if you connect your cell phone charger to your mobo only solution is to repair the charging port oh 🙁 but thanks for the answer anyways! sorry mate...🙁 if you found a solution select /post it Upvote 0 Downvote
