G
Guest
Guest
hi there
i need some help with my laptop, to be honest its getting very annoying.
anyway this is whats happening, if i restart or shutdown, as you do a lot using pcs, occasionally my laptop wont startup again.
ie, i have no display, dont get a post screen, and the laptop just sits there with the power light and hd light on.
if i leave it a few mins the hd light goes off, but nothing happens, no booting or anything.
if i sit there for ages continually turning the laptop on and off, eventually i can get it to come up with the post screen and boot, but when i say ages, i mean ages.
please help!
thanks
please help!
thanks
