Question Laptop randomly crashes when it's running on battery ?
Oct 12, 2024
6
After so many attempts to solve this issue, i decided to open this thread and hopefully will find the right fix for it. So after doing some researches ,a lot of people owning vivobook pro models are expiencing the same issue . I have tried many solutions, but none seem to work, so i decided to check the laptop fully on my own.
Recently I just realized that the laptop never crashes when It's plugged in, but when running on battery it randomly goes pitch black or pixelated screen and I have to do a force restart everytime (you never know when it happens).
So i bought another battery, thinking this might be the issue, and guess what: It did not fix it!
There must be something between battery and motherboard that seem to be not right. Any ideas ?
After so many attempts to solve this issue, i decided to open this topic and hopefully will find the right fix for it.
What have you done prior to the creation of this thread?
We can narrow down that you own an Asus Vivobook Pro. Can you please state the model/SKU to your laptop? Would help us understand it's specs and what you have to work with.
the crash never happens,but when on battery, it randomly goes pitch black or pixelated screen and you have to do a force restart everytime(you never know when it happens).
You mean the laptop locks up and the only way to get out of it is a reboot? Can you replicate the issue? Can you take a picture of the pixelation next time it happens?
What OS are you working with? Have you checked to see if the laptop is pending a BIOS update?
Thanks.
Windows 11.
As for the BIOS, I reset it, even updated it later but the issue still occurs . Imagine this happened while i was installing win 11 even, while on battery.
Sorry, i just saw now properly the reply you sent me.
The SN is: N1N0CX112156020
Yes , the screen suddenly turns black or sometimes full of colorful pixels all over the screen and you can t do anything, but force restart. The issue happens mostly when i start using discord or whatsapp web for calls. I will find a similar pic of another vivobook model and send it here.
so there is no solution then. how do i delete this thread
  • Adjust Power Settings: Go to Control Panel > Power Options and select a balanced or high-performance plan. You can also customize the advanced settings to ensure that the laptop doesn’t go into a low-power state too quickly.
  • Update Drivers: Visit the manufacturer's website to download and install the latest drivers for your laptop, especially for the graphics card and chipset.
  • Check for BIOS Updates: Look for any available BIOS updates on the ASUS support page for your model. Updating the BIOS can sometimes resolve hardware compatibility issues.
  • Run Diagnostics: If your laptop has built-in diagnostics (often accessible during boot), run these tests to check for hardware issues.
  • Consider Hardware Issues: If none of the above solutions work, there may be a deeper hardware issue, possibly with the motherboard itself. In this case, consulting a professional technician might be necessary.
Thanks for the advices. I kept the laptop on Balanced and High Performance and still persists... Possibly might be a chance to fix it with power settings, just didn t figure it yet. Worst case , harware can be then..
